Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 6 of 6
  1. #1
    Default I have a 120 on my Quantum and
    I have a 120 on my Quantum and the motor will slowly lower itself when its raised up.
  2. #2
    Default "Sounds like a leak in the sys
    "Sounds like a leak in the system I had to do mine on a 125hp. Look for fluid leaking out of one of the lines, or cylinder. Most times it is the seals in the cylinder itself. The new seals are very cheap. If yours is like mine with two holes on top of the cylinder. you need a spanner wrench to open the cylinder to put in the seals."
  3. #3
    Default I cannot see any leaks. All th
    I cannot see any leaks. All the lines and cylinders are clean. It falls really slow and comes up fine.
  4. #4
    Join Date
    Apr 2008
    Location
    Grandbay, New Brunswick, Canada
    Posts
    123
    Default "Ls1axle There are 2 sets of
    "Ls1axle There are 2 sets of cylinders 1 for running and 1 for trailering, you do not mention which is drifting,however your problem is the ram is by passing internally,you will need to remove the ram and have it repacked, any good hydraulic shop can do that in less than 1 hr and a couple bucks for a seal kit. This is not a major issue. If it were me I would get the shop to remove the assembly and reinstall assuring the system is bled properly. $ 100.00 should cover it, or maybe you know a truck or forklift mechanic. Hope this helps,let me know how you make out.
    Michael"
  5. #5
    Default I think im going to take it in
    I think im going to take it in.
    Stephen
  6. #6
    Default Bought seals for 5 bucks and n
    Bought seals for 5 bucks and now its fine.
Similar Threads
  1. 95b 120hp Force
    By bigb6065 in forum Chrysler Force Outboard Forum
    Last Post: 06-06-2009, 01:38 AM
  2. Force 1996 120hp
    By essex_marine in forum Chrysler Force Outboard Forum
    Last Post: 01-22-2009, 02:57 PM
  3. Just bought a 120hp Force
    By bbhskynyrd in forum Chrysler Force Outboard Archive
    Last Post: 09-24-2008, 01:26 PM
  4. Force 120hp
    By roger55 in forum Chrysler Force Outboard Archive
    Last Post: 05-21-2008, 08:01 PM
  5. Tachometer for Force 120hp
    By fishnut in forum Chrysler Force Outboard Archive
    Last Post: 02-11-2007, 07:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
