1984 48hp evinrude wont idle without choke help
B
Bob Setzer
Guest
"Hello, My 48 hp evinrude &#40
"Hello, My 48 hp evinrude (spl) will not idle or run without the choke (brand new elec choke)when it almost shut's down i click the choke again and it run's for another second or so, then if i do not click the choke again she will shut down, Thank's in advance for your help.... Bob}"
"Its not the electric choke or
"Its not the electric choke or the fuel pump, i replaced both today, any suggestion's ? thank's..... Bob"
"Try running some "Sea Foa
"Try running some "Sea Foam" through the fuel system, often that stuff will clear clogged needle valves and seats. Cheaper and a lot less trouble than a carb and fuel pump rebuild."
"sea-foam,is not a cure-all,bu
"sea-foam,is not a cure-all,but more of a maintenence item...
after a thorough carb job,the use of sea-foam on an occasional basis,will help."
"Thank's again for your ti
"Thank's again for your time guy's, But, even with both carb's rebuilt, new fuel pump, new elec choke, it's still doing the same thing... Please help, thank's... Bob"
Then I'm afraid You have t
Then I'm afraid You have to go back to the one that rebuilt the carbs.
Your idle circuit does not seem to work properly as the engine obviously runs when You inject fuel with the primer.
