"I have two 1978 318 engines t
"I have two 1978 318 engines that have closed loop cooling. One engine is approaching 200 F at 3500 rpm. The other approaches 185 F at 3500 rpm. I will be pulling off cooling components this fall to try to find the restriction. Any suggestions on where to start? How do you test these components (transmission cooler, heat exchanger, pump, other)?
Thanks in advance for the help,
Jeff"
Jeff"
