Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 4 of 4
    Jun 2008
    Orange , Calif, USA
    6
    Default Morning... Can anyone tell
    Morning...
    Can anyone tell me how to change the lower unit fluids on this engine?
    On the lower unit i see the fill screw on the front of the bulb but not sure as to how to guage complete fill? Will it overflow thru weep hole just under capitation plate?
    Does anyone have a step by step?}}
    Apr 2008
    Auckland New Zealand
    145
    Default "There are two drain plugs, on
    "There are two drain plugs, one at the bottom and one at the top, take both out, drain the oil and refill from the appropriate squeezy container, from the BOTTOM plug, when oil runs out the top hole you quickly replace the bottom plug.
    This is to ensure no air gets trapped in the g/box."
    Richard NEWSTEAD's Avatar
    Richard NEWSTEAD Guest
    Default "I have a 140 HP chrysler outb
    "I have a 140 HP chrysler outboard motor and wish to change the gear lube(lower unit) I see a fill port next to a vent port. There are 2 port
    or screws on the bottom, one on the underside
    and one on the lower right side of the lower unit.
    From what port(hole) does one drain,and or top
    up from. Rick"
    May 2007
    Albany, NY, US
    59
    Default don't touch that screw und
    don't touch that screw underneath! that screw holds the gears in place.
  1. 1991 Force 120HP lower unit
    By spencergarbs in forum Chrysler Force Outboard Forum
    Last Post: 07-15-2009, 07:37 PM
  2. 1994 Force 120HP lower unit
    Last Post: 07-02-2009, 07:48 AM
  3. 120hp Force Lower Unit
    By pelermon in forum Chrysler Force Outboard Archive
    Last Post: 07-26-2006, 09:18 PM
  4. 1992 force 90 HP outboard lower unit rebuild
    By coolchange in forum Chrysler Force Outboard Archive
    Last Post: 05-16-2006, 11:32 AM
  5. Outboard 120hp force 1991 possible problems
    By darin in forum Outboard motors archive 2000-2004
    Last Post: 04-26-2002, 09:01 AM
