"94 Evinrude 200hp Ocean Pro.
"94 Evinrude 200hp Ocean Pro. The motor has been running good all season, 12 launches without a problem. Last time out to the lake, motor started, idle was low and motor would stall. Motor also stalls when moving into gear neutral.
What I have done so far:
1. Verified fuel in tank.
2. Replaced fuel line, primer bulb and fuel filter.
3. Verifed getting fuel out of the fuel pump.
4. Checked spark - good on 5 out of 6 cylinders
5. Replaced coil and plug wire, still no spark.
Stator was replaced about 18 months ago.
Per the Selco manual, I believe I should be testing the power pack, but dont have the tools for it.
Am I describing a bad power pack, or are there other possibilities that I can troubleshoot first?
All help / questions / advice is appreciated.
Robert"
Robert"
