Results 1 to 5 of 5
  1. #1
    Default I just got this scott atwater
    I just got this scott atwater outboard 5hp bail-a-matic and dont know anything about it. guy said it ran 7 rears ago and was the last time he used it. what should i look at to make sure it is ok. It has awsome compression and wverything looks ok except for a sticky trotle and cant figure out spark yet.
  2. #2
    Join Date
    Jul 2006
    Location
    , Ontario, Canada
    Posts
    230
    Default "I have owned a 1954 16HP with
    "I have owned a 1954 16HP with bail-a-matic since the early 70's (It was my fathers then). I'm not an expert on the motor itself except to say that parts are definitely harder to find than a Johnson/Evinrude, or even Mercury of the day. When you say you can't figure out spark, does that mean that it has none, or that you haven't tested it yet?
    If you need, there are some parts listed at http://tinyurl.com/5jbekh
    One name that keeps coming up with every Scott Atwater outboard is "The Scott Guy" - http://web.a-znet.com/~scottguy/index.html"
  3. #3
    Default no spark and would anyone know
    no spark and would anyone know the fuel mix ratio?
  4. #4
    Join Date
    Jul 2006
    Location
    , Ontario, Canada
    Posts
    230
    Default "Not knowing the year, I could
    "Not knowing the year, I could only guess. My 1954, which is gold, with bail-a-matic is 1/2 a pint to the gallon.
    If you have no spark at all, it's time to remove the flywheel and check the coils for cracks. Replace if necessary (the tinyurl link above has them). Also check the points to make sure they aren't pitted, rusted etc. The point gap on my old Scott-Atwater is .020 (it seems all the other ones from the same era are the same).
    Good luck."
  5. #5
    Default Re: I just got this scott atwater
    I was having problems with spark on the 7.5 bail o matic. Points needed cleaning. Bail O matics have water pump issues.
Similar Threads
  1. Scott 3 1/2 hp
    By lilybo in forum Gale Outboards
    Last Post: 08-16-2010, 09:07 PM
  2. 1946 scott atwater
    By redhoss in forum Gale Outboards
    Last Post: 07-16-2010, 09:22 PM
  3. 1955 scott atwater 5hp need propeller
    By firemanlowden in forum Gale Outboards
    Last Post: 07-15-2010, 06:10 PM
  4. Infopicbs of 19478 atwater firestone
    By 47bandit in forum Archive 2003-2009
    Last Post: 11-12-2007, 05:19 PM
  5. Parts needed for Scott Atwater and Sea King
    By wayne777 in forum Archive 2003-2009
    Last Post: 03-19-2007, 08:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
