1973 Chevy inline 165
vintage
"Does anyone out there have on
"Does anyone out there have one of these early to mid seventies 165 inline sixes that has an un-molested Mercruiser wiring harness on it. I need some one who can just take a look at a few things on the engine and then answer a few questions. I need you to make sure that the electrical system does not have a ballast resistor or external voltage regulator.
Thanks,
Eric <><"
The wiring diag I have for the
The wiring diag I have for the 165 shows a 2 wire alternator; no external reg.
It also shows a white ballast wire running from pin 9 of the engine plug to the + terminal of the coil. There is no separate visible ballast resistor.
Does that help?
Rod
