T
Tarek
Guest
"When I push throttle down to
"When I push throttle down to run the boat. I get a steady beeping sound when the boat speed goes over 4000 RPM. The beeping does not go away until I slow down. Everything runs great under 4000 RPM's. Noone knows what the problem is.
There are no fault codes, temp. is good and not overheating. I replaced water pump, throttle position sensor, crank shaft sensor, and spark plugs.
PLEASE PLEASE HELP if you can.
