Changing engine coolant TAMD 41A
wingspar
"I'm trying to change the
"I'm trying to change the engine coolant in a TAMD 41A. I'm set with the diesel coolant premix. The manual say to drain it but doesn't say where. What is the best way to drain all the engine coolant??
Thanks,
Dave"
Block drain just forward of fl
Block drain just forward of flywheel housing starboard side. Two drain cocks or plugs on bottom of manifold just up from block drain. Plug on bottom of turbo housing and plug on bottom of heat exchanger.
