Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
Results 1 to 3 of 3
  1. #1
    Join Date
    Aug 2008
    Calgary, Alberta,
    Default "I am a new owner of an approx
    "I am a new owner of an approximately 1971 70hp, which is in overall excellant shape. It has had rebuilt carbs, the ignition gone through and the timing set in recent weeks. It idles very well when not in gear, but stumbles and stalls when put in gear. If you take off right away it runs perfectly. I bought this boat/engine combination from a small marina after they became frustrated in their inability to solve the problem. These are guys with 25 years+ experience, so I don't take their abandoning the cause lightly. This is the only problem with the engine, so I thought it worth a try here. Could it be something dragging in the gear case, which overwhelms the engine at idle? I am a collector of classic and antique boats, and very far from a mechanic. I only do the most basic of work myself.
    Other than this, I am very happy with the engine. Looks to be low hours and very well cared for. The spark plug wires say 1971 on them - are these date coded? I also am re-storing a 1946 Gar Wood Sedan with the original Chrysler Royal 8, so I will take my myriad of questions on that engine to the inboard forum.
    Thanks for any help or suggestions."
  2. #2
    Join Date
    Apr 2008
    Auckland New Zealand
    Default My 90HP did this shortly befor
    My 90HP did this shortly before it blew up...it may be the crankcase seals need replacing.
    I disconnected the starter cut-out and started it in gear....this is NOT recommended but it got me out of the poo for a while.
  3. #3
    Join Date
    Jun 2006
    Claremore, Oklahoma, USA
    Default "Post your question with these
    "Post your question with these guys.
    Franz (on the Forum there) is especially knowledgeable on these old Chrysler motors.
Similar Threads
  1. 360 Chrysler wonbt idle
    By Dean Travis in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 05-23-2008, 06:47 AM
  2. 1971 Mercury 800 starts wonbt run on low idle or in gear
    By 71_avenger in forum Mercury Mariner Outboard Archive
    Last Post: 07-26-2007, 11:09 AM
  3. 1983 Merc 70hp Wonbt idle gas leaking from bottom
    By DanB124 in forum Mercury Mariner Outboard Archive
    Last Post: 07-02-2007, 03:33 PM
  4. 98 70hp yam wonbt idle
    By Kippo in forum Yamaha Outboard Archive
    Last Post: 05-22-2007, 11:33 PM
  5. 30L wonbt idle in gear
    By ohmonterey in forum Mercruiser Sterndrive Archive
    Last Post: 05-21-2006, 08:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
