M
Mark Buenzow
Guest
"I have changed the head gaske
"I have changed the head gasket and all of the gaskets around the head and still I get water in my oil. No water in the cylinder heads, just the oil. I have read another log on this same problem and they stated you should use sealant due to some of the head bolts screwing into the water jacket. Is this correct? If so any rtv high temp will work? should I put it in the bolt holes, or, just around the whole gasket? What should the head be torqued to? I also have a leak in the exhaust (down tube? I am new to boats and terminology) where it connects to the manifold. What is the torque for those bolts as well."
