joereeves
Gold Medal Contributor
"The leaf valve of the reed pl
"The leaf valve of the reed plate should cover the related slots completely. The leaf should not be broke or cracked at any area, nor should it be raised away from it to any great degree. It requires a visual inspection.
However, as I understand it by your explanation above, when you moved the #3 carburetor to the #2 cylinder location, the problem moved to the #2 cylinder. If this is the case, the problem is the carburetor and nothing else."
