J
jkrampe
Guest
"I have reasonly bought a dt 6
"I have reasonly bought a dt 65 on a lund 16.5 boat,
when I try to use it, it will idle fine for about 3-5 min and seems to run out of fuel.and if it is moved above idle,choke helps keep it alive...
I cleaned the carbs. and rebuilt the fuel pump,still this happens.
what size fuel line should be on this motor? it currenty has a 3/16 ID. line and all other motors seem to be 5/16" to 3/8" could this be my problem???
the fittings on the fuel tank and motor is the same 3/16 ID size, do I have all the wrong parts???
thank you if you can help..."
