MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 14 of 14
  1. #1
    Default Anyone out there used seafoam
    Anyone out there used seafoam before in the gas tank? How did you like it? do you recommend it?
    John
  2. #2
    Join Date
    Jul 2008
    Location
    enterprise, alabama, usa
    Posts
    24
    Default I have had 2 different repair
    I have had 2 different repair shops to tell me that I need to run 2 tanks of fuel with this seafoam in hem to help my motor. my motor set for 6 to 8 months without being run. they both said it won't hurt and might help me.
  3. #3
    Join Date
    Jun 2008
    Location
    , nj, usa
    Posts
    51
    Default beware of a lot of smoke
  4. #4
    Join Date
    Jul 2008
    Location
    , Texas,
    Posts
    25
    Default My 115 hp 4 cyl motor sat 2 ye
    My 115 hp 4 cyl motor sat 2 years without being started. I cleaned to bottom 2 carbs and added seafoam to a gas tank with new gas. It appears to be running much better now than it did when it first started idling without shutting down. I do get a lot of smoke. Mostly upon startup and it dies down after a few minutes. But I think the seafoam kept me from having to clean my top 2 carbs.
  5. #5
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,114
    Default "Seafoam is like alot of other
    "Seafoam is like alot of other "cleaners" or "conditioners".
    Seafoam should help remove carbon, gum, varnish etc.
    Certainly can't hurt as a "preventative" and would be similar to running fuel conditioner in your vehicle.
    Some guys swear by it, others don't bother.
    I'm somewhere in the middle - can't hurt, but there really is no "magic in a can" - I tend to believe alot of the results are exagerated, not on purpose, but just because someone "thinks" they notice a great improvement.
    I decarb my motors once a year with Mercury PowerTune and then simply run gas stabilizer (as is recommended by all the mfgs if you use gas containing ethanol), and have never had a gummed carb, fouled plug, stuck reed etc - and that is on my 3 outboards, the newest a 1991 model, with a total operating time well in excess of 5000 hours amoungst the 3 motors.
    If you do your annual maintenance and do not abuse your motors, Seafoam may very well help, but it's not "mechanic in a can" and can not be a substitute for proper care..."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  6. #6
    Join Date
    May 2008
    Location
    Northwest IL, IL,
    Posts
    44
    Default im one of those guys that swea
    im one of those guys that swear by it.... That stuff should be used fairly often... it will make a world of difference and youll be able to tell. With the price of gas the way it is now It cant hurt to keep your machine running as smooth as possible.!
  7. #7
    Join Date
    Jul 2008
    Location
    wareham, ma, plymouth
    Posts
    78
    Default What is Seafoam and where can
    What is Seafoam and where can I buy some.
  8. #8
    Join Date
    Jul 2008
    Location
    Posts
    24
    Default "Solving Engine Problems Easil
    "Solving Engine Problems Easily and Inexpensively
    rough idle, hesitates, stalls, pings or has an after run problem this is often due to carbon buildup.
    moisture needs to be removed from fuels or an anti gel or de-icer or injectors need cleaning .
    When fuel stabilization and engine fogging is needed us Seamfoam Treatment.
    look on internet or ebay or your local Boat Repair Shop. Around $9.00 per can."
  9. #9
    Join Date
    Jul 2008
    Location
    , Texas,
    Posts
    25
    Default I get mine from Wal-Mart for a
    I get mine from Wal-Mart for a little over $5 per can.
  10. #10
    Join Date
    Jul 2008
    Location
    Posts
    24
    Default can't find this at my walm
    can't find this at my walmart.
  11. #11
    Default "Try pep boys ,or another auto
    "Try pep boys ,or another auto supply store ."
  12. #12
    Join Date
    Jul 2008
    Location
    Posts
    78
    Default "Found it at Auto Zone. Tha
    Thanks, Dan"
  13. #13
    Join Date
    Sep 2006
    Location
    Baton rouge, La, USA
    Posts
    2,501
    Default find it here at this site....i
    find it here at this site....i believe in supporting the people that support us....i have used sea foam and whether it did any good or not i do not know...i have a 18 gallon built in fuel tank...what it did do was either remove some black gooey stuff from either the tank or the inside of the hose from the tank to my filter...the filter was full of it after about a 10 gallon run....either way i was glad to get it out of the system...
  14. #14
    Join Date
    Sep 2006
    Location
    Posts
    2,501
    Default i was going to replace the hos
    i was going to replace the hose but i had some excess in the line and cut about 6 inches off the end...it was slick and clean inside and the outside looked good so i did not replace it...ran more seafoam thru the system and the filter was clean..so i was wrong in saying i didnt know whether it did any good...it got that stuff from somewhere..
Similar Threads
  1. yamaha 115 enduro reviews
    By sanurdiver in forum Yamaha Outboard Forum
    Last Post: 08-29-2012, 12:20 PM
  2. Sea Foam
    By wrench in forum Mercruiser Sterndrive Archive
    Last Post: 01-05-2008, 11:10 AM
  3. Sterndrive Engineering SE106 reviews
    By sr_245 in forum Mercruiser Sterndrive Archive
    Last Post: 09-23-2007, 01:37 PM
  4. Suziki DT25 Conversion and Reviews Help
    By 181915mile in forum Suzuki Outboard Archive
    Last Post: 05-08-2007, 06:46 PM
  5. 2001 or earlier 2 stroke 125 HP Mercury Good or Bad Reviews
    By Pat D. in forum Outboard motors archive 2000-2004
    Last Post: 09-06-2001, 10:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
