MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 3 of 3
  1. #1
    noahsohn9642's Avatar
    noahsohn9642 Guest
    Default "Because of water leaks(oi
    "Because of water leaks(oil leaking from the gear case)I tried to change the seals but after removing the water pump base I couldn't remove the bearing assembly and .... My engine is 74' merc 500 4cyl 50HP. To remove a drive shaft and a prop shaft,Do I need a special tools? Should I disassemble drive shaft first or prop shaft first? I have a factory manual and diagrams but It doesn't help. Someone can help me? noah"
  2. #2
    Join Date
    Jul 2008
    Location
    wareham, ma, plymouth
    Posts
    78
    Default "Noah, the first thing you sho
    "Noah, the first thing you should do is a preassure test to see what seals are leaking. To replace all the seal in a lower unit is a project. You might get lucky and just have to replace the seal under the water pump or the shift shaft.These 2 are common on leaking and easy to get at."
  3. #3
    noahsohn9642 Guest
    Default "OH,I didn't know that.I t
    "OH,I didn't know that.I think I made more problems. I already pulled out a shift shaft and I couldn't put it back.The drive and prop shaft stuck in forward position and a small metal piece dangling inside a shift hole.It seems like impossible to back in. what shall I do now?"
Similar Threads
  1. Removal of lower unit seals
    By joea in forum Johnson Evinrude Outboard Archive
    Last Post: 03-29-2009, 07:33 PM
  2. Lower Unit Seals
    By jrs in forum Johnson Evinrude Outboard Archive
    Last Post: 12-30-2006, 11:54 PM
  3. Lower unit seals
    By spdrcr03 in forum Mercury Mariner Outboard Archive
    Last Post: 03-11-2006, 12:48 PM
  4. Best way to get lower unit seals out 90 150 hp
    By tubbs in forum Johnson Evinrude Outboard Archive
    Last Post: 02-28-2006, 08:43 PM
  5. Seals lower unit
    By gary in forum Outboard motors archive 2000-2004
    Last Post: 02-02-2002, 09:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
