AQ125B Is auto water pump gasket the same
jamie392
"I need to put my water pump b
"I need to put my water pump back on but it is taking the marine shops awhile to get that gasket, is the auto one interchangeable?
Thanks!"
"Hi Louis,
It would be bett
"Hi Louis,
It would be better for you to start a new thread with your question.
Cheers, Tom"
"hi louis, yes i think you can
"hi louis, yes i think you can I just did it, but it still is kinda leaking
You need to take off the heat exchanger which is pretty easy and then pull the pump, putting it back in is kinda hard because that new gasket pushes the pump downards because it needs to be compressed between the head and the pump."
"Jamie, I think I suggested on
"Jamie, I think I suggested on another thread that you remove (or loosen) the head to change that gasket. If you choose not to, you can expect that gasket won't seal well 9 times out of 10."
