"Hi Guys,
thanks for the fe
"Hi Guys,
thanks for the feedback and sorry for taking so long to reply. haven't changed a thing but noticed what i believe is "heavy" fuel consumption. ran it for about an hour WOT and burned 3 gals of gas. not sure if this is "heavy" but also noticed lots of smoke and when I tilted the motor up gas/oil was making quite a large slick on the water.
I ran a tank of clean gas with Sea Foam and it seemed to make it run a little smoother. the big problem is when you crank the throttle wide open it seems to miss and sputter for 30-45 seconds then it clears itself and runs pretty good at WOT.
could it be a setting or do i need to clean/rebuild the carb ?"
