Overheated engine amp siezed
roger766
"hi i have some questions i h
"hi i have some questions i have a johnson 140 1984 and while i was driving it suddenly stoped ,check the engine it was extremly hot on the left upper cylinder it will not crank not even by hand. so i took out the spark it had someting melted on it looks like metal. when i dry dock took out clynder head and saw piston also has some type of melted materail on it. as soon as i took out the head it now turns freely by hand ,do i have to replace or rebuilt the whole engine or is that cylinder repaireble."
"The main repairs can pertain
"The main repairs can pertain to that one cylinder but there will be other repairs encountered (piston rings, s/plugs, carb kits, etc). The engine must be completely dismantled, cleaned, inspected, etc in order to perform the needed overhaul."
