Results 1 to 2 of 2
  1. #1
    Default "My Brother-in-Law Has a 2001
    "My Brother-in-Law Has a 2001 cruiser with twin 7.4 MPI Horizons. The starboard engine is alway hard starting. When it does start it runs like it's running rich. The black smoke confirms this. We replaced the fuel pump, fuel cooler, regulator and the Fuel/Water separator even reset the computer. The engine runs perfect beyond idle. I'm thinking it's the idle circuit and/or its components. Maybe a partially plugged air oriface. Anyone care to comment or have any ideas?
  2. #2
    Join Date
    Jan 2008
    Lakehills, Texas, USA
    Default "Maybe dirty injectors are not
    "Maybe dirty injectors are not letting the fuel atomize properly. I would also verify base timing. Verify fuel pressure and Yes, check the idle air control and it's ports are clean and the throttle body as well. If all else fails try swapping ecm's and see does problem follow.
Similar Threads
  1. 8.1L Horizon problems...please help
    By cadde300 in forum Marine Power Engine Forum
    Last Post: 07-20-2010, 09:26 PM
  2. Horizon 74L Hard Starting When Warm
    By motorhead_pat in forum Mercruiser Sterndrive Archive
    Last Post: 11-04-2008, 06:32 PM
  3. 454 HORIZON
    By RONBEX in forum Mercruiser Sterndrive Archive
    Last Post: 03-18-2008, 10:13 PM
  4. Starting problem
    By mark somerville in forum Chrysler Force Outboard Archive
    Last Post: 08-14-2007, 09:18 PM
  5. Horizon 74 vdrive
    By pfederlin in forum Mercruiser Sterndrive Archive
    Last Post: 10-04-2006, 09:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
