"I have read this forum lots a
"I have read this forum lots and lots and learned tons. Thank everyone for that. Problem....1998 merc 50 4 stroke, above 2000 rpms awsome. Below 2000 rpms horrible. Idles rough (only in gear), so bad sometimes it shakes the boat. May go through a a period of a few seconds where the problem goes away. In neutral it is perfect. Carbs pulled and cleaned, carbs sync'ed 3 times. Plugs ok. Seeems like when I pull the bottom plug wire (cyl. 4) no effect on idle. Any ideas? All this work was done by a reputable local shop but they cant seem to get it right. Even thought it was the auto start switch (which was bad) and bypassed it to work like a choke on every other outboard on the planet. Didnt help."
