"I've got a problem shifti
"I've got a problem shifting into reverse. Starting last year it was kind of difficult to get to reverse (thought it was the shifting column at the drivers seat). Now it won't go into reverse at all. Sorry if I'm calling the specific parts/point by the wrong name, but neither of my manuals (Clymer's and Seloc really covers this very well). I removed the shifting cable at the engine, and the components from the drivers seat to the engine compartment work just fine.
Next I tried to manually engage it from the engine to the outdrive. Forward works fine, and I got it into reverse one time. After that, no matter how hard I push on the casing guide, it won't go into reverse.
I can see where this cable goes through the transom, but don't see how it goes into the upper unit.
Do you think it's the cable? Since it works so easily in the forward direction it seems unlikely that the cable is frayed.
It appears that in order to get to the outdrive end of the cable you need to pull the upper unit away from the transom. Is this correct? If so, this seems like a lot of work to change a cable.
Any ideas or suggestions?
Thanks a ton.
Bob"
Thanks a ton.
Bob"
