"I have two different props th
"I have two different props that the previous owner of my boat gave me. The one I have been using is the 48-66450 A4 which I believe is a 14.25 inch , 17p . This prop has very wide blades. I also have a 48-36016 A4 which I presume is similar in performance but different in appearance. It measures about 7 13/16ths from centre of hub to end of blades which leads me to believe it is at least 15 1/2 in diameter but has narrower blades.
I can`t seem to locate any info as to what differences in performance I might see between the 2. When looking in the michigan prop crossover, it gives you the closest match in their numbers and both props cross over to the same michigan number.
I can no longer accurately measure the 66450 I had on my boat because the island that was hidden by high tide sort of removed large portions of that prop.
Can anyone here tell me if I would actually notice any difference in performance with these 2 props?"
