Is a plastic tank better then an aluminum one
briang0
I found out I have a 30 gal fu
I found out I have a 30 gal fuel tank. I have a BB chevy which does not give me much crusing range. I want to replace it so I am asking for some opinions on which material is better. I'm sure each has there own merits.
"Although plastic tanks genera
"Although plastic tanks generally cost less and do not corrode, they do permeate fuel. This creates a gasoline odor which can not be overcome. This is the reason most boats with living quarters use aluminum tanks."
Plastic tanks do not have baff
Plastic tanks do not have baffels so if going larger would recommend properly designed aluminum tank. They cost about 10/gallon from what I found.
