Results 1 to 4 of 4
Thread: GrayMarine
  1. #1
    Richard Conn's Avatar
    Richard Conn Guest
    Default "I have a 1949 Gray Marine 4 c
    "I have a 1949 Gray Marine 4 cylinder Phantom Four-45 motor in my Penn Yan. I changed the oil to Pennoil multi vis. When I ran it after the oil change it was not getting any oil pressure. What could be the problem?? It runs fine but shows no oil pressure. I know that first I must check with a new oil pressure gauge but I know for sure that its not the gauge. What could be the problem? Oil Pressure releif stuck? Help. Rick Conn Boulder Colorado. email [email protected]"
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,558
    Default "Careful! You simply might no
    "Careful! You simply might not have gotten the pressure up yet--I assume you clicked her off immediately.
    Here's what I would do: Pull the plugs. Rig up a a new mechanical pressure gage. Crank her over until (hopefully) the pressure comes up.
    It might simply be a bad gage, but do not under any circumstances assume you can go boating this way.
    Jeff"
  3. #3
    Join Date
    Oct 2007
    Location
    orange, TX, usa
    Posts
    2
    Default Where do I find parts for a Gr
    Where do I find parts for a Gray Marine motor 4 Cyl I need a oil cap for the oil filler tube I will need other parts as I go along with the rebuild
    Doug
  4. #4
    Join Date
    Feb 2004
    Location
    Suamico, Wisconsin,
    Posts
    201
    Default "That's an easy solve. Gr
    Gray Marine INC
    310 North 6th Street
    St Charles, IL 60174
    630-485-5007
    Fax 630-584-9141
    Ask for Kim, they have the entire Gray Marine OEM parts inventory and are wonderful people to work with. They take phone orders if you have some part numbers or descriptions.
    Cal"
Similar Threads
  1. GrayMarine AMC 327 Oil Lines
    By cal in forum Gray Marine Gas Engine Forum
    Last Post: 10-27-2010, 09:19 PM
  2. Graymarine 188 vs 225
    By always_looking in forum Gray Marine Gas Engine Forum
    Last Post: 12-20-2009, 08:58 AM
  3. GrayMarine 671 Diesel
    By Mark Crech in forum Detroit Diesel
    Last Post: 03-24-2004, 12:31 AM
  4. Graymarine 422 again
    By Gregory Williams in forum Gray Marine Gas Engine Forum
    Last Post: 03-18-2004, 07:53 AM
  5. Graymarine 422
    Last Post: 03-04-2004, 09:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
