Results 1 to 2 of 2
  1. #1
    Default "I have a 1977 25 HP long shaf
    "I have a 1977 25 HP long shaft Evinrude needing lower unit repair. I can not remove the unit as the long stud at the rear will not break free. I have tried heat, cold, WD 40, and 2 lock nuts to turn the stud. The gear case and extension move slightly at the front. The stud seems locked in all 3 components. Any suggestions. I'm afraid I will break one of the castings. Bill"
  2. #2
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    Default "Two ways of doing it, both &#
    "Two ways of doing it, both 'naugty' and depending on what kind of tools You have.
    1: The easiest way, cut with a metal saw 1/2" above the gear case flange through the extension and the bolt. That leaves about 1/2" of he stud left in the gearcase to use a vice-grip or similat to remove the remaining bolt without ruining the threads. The extension you put in a vice and press out the stud. (Might need a couple of tonns and some heat)
    2: Same procedure, but you cut at the flange. You then need a steady machine drill to drill out the stud, in worst case install a helicoil for the new one.
    Good Luck!"
Similar Threads
  1. 1977 70 hp evinrude leaking oil out of lower unit
    By wen4222 in forum Johnson Evinrude Outboard Archive
    Last Post: 12-01-2009, 10:16 PM
  2. Lower unit removal 1977 200 Johnson
    By mdr584 in forum Johnson Evinrude Outboard Archive
    Last Post: 02-27-2008, 09:16 AM
  3. 1977 35 hp Johnson seahorse lower unit removal
    By maw77712 in forum Johnson Evinrude Outboard Archive
    Last Post: 07-10-2006, 10:36 AM
  4. 1977 evinrude 175 hp v6 lower unit
    By John Kramer in forum Johnson Evinrude Outboard Archive
    Last Post: 04-30-2006, 02:14 AM
  5. 1977 evinrude 175 hp v6 lower unit
    By John K in forum Johnson Evinrude Outboard Archive
    Last Post: 03-24-2006, 11:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
