1998 40 HP Mariner impeller change
C
Chuck Hathaway
Guest
"I have taken the four bolts a
"I have taken the four bolts and the nut from the trim tab off, but the lower unit only drops about an inch. What else needs to be done to remove the unit?"
I have a 98 40 hp merc. How d
I have a 98 40 hp merc. How do you change the water pump?
"you must disconnect the upper
"you must disconnect the upper portion of the shifting rod from the lower portion on shifting rod. My terms may not be correct. There is a nut that connects them, it is found toward the front of motor."
