Points
hutchusmc
I have the points adjusted to
I have the points adjusted to the correct gap using a feeler gauge. After I run the engine the points change position and are now closer than what I set them at. I made sure the points definantely secure before putting the cap back on. What could be causing this? Is it because of the dwell lpease help.
"Dan,
Did you lubricate th
"Dan,
Did you lubricate the cam? They might have just seated themselves somewhat. If your engine was not running erratically I would think that it was a typical situation."
"Better yet, toss them out and
"Better yet, toss them out and go with a Petronix electronic kit. Works great!
Jeff"
Thanks fastjeff I think I'
Thanks fastjeff I think I'm going to go out and buy that conversion kit and be done with the points all together.
"When you change to the electr
"When you change to the electronic ignition kit, check/verify your timing before running it."
"Changing point gap / dwell re
"Changing point gap / dwell readings can also indicate worn distributer shaft bushings. Get rid of the points, but check the shaft play too."
