MarineEngine.com - Your online store for all types of marine engines and boat parts.
Order by phone
(800) 209-9624
Monday - Friday
8:30 AM - 5:30 PM EST
Safe Online Orders
Comodo Enhanced Security
Special $9.95 Flat Rate Shipping
Boat Repair Forum Boat Repair Forum     Boat Video Gallery Video Gallery
Home | Contact | Shipping | Returns | Cart View your shopping cart.
Part Number Search
Shop by engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Click for MerCruiser parts and manuals!
Results 1 to 12 of 12
  1. #1
    Join Date
    May 2006
    Location
    Posts
    151
    Default How do I manually turn over my
    How do I manually turn over my 3.0L? The engine mount is right in front of where the crank is.
    I'm tryn to lube it up good before starting it. This is also a test to make sure its not locked up.
  2. #2
    Join Date
    Apr 2006
    Location
    Posts
    861
    Default "You can also remove the coil
    "You can also remove the coil wire and crank it with the starter. Pull the spark plugs to make it easier on the starter and if you want to squirt a little light motor oil in each cylinder, that won't hurt, either. Pulling the plugs also keeps it from drawing fuel into the cylinders."
  3. #3
    Join Date
    Feb 2006
    Location
    cave City, AR, USA
    Posts
    88
    Default "Take Jim's advice. Plugs
    "Take Jim's advice. Plugs out, squirt of WD40 type oil and if she won't turn over with starter, you've probably got problems.
    Bob"
  4. #4
    Join Date
    Apr 2006
    Location
    Posts
    861
    Default "NOT WD 40! That has cutting o
    "NOT WD 40! That has cutting oil in it. Light motor oil. If the rings are stuck to the cylinders, there will be problems anyway but there's no point in scoring the cylinders by using WD. I don't think PB Blaster has cutting oil, though. If it doesn't, use that. PB is a lot better as a penetrant, IMO and I stopped using WD as soon as I found out about PB Blaster.
    I would be tempted to remove the starter and make sure it's OK before doing anything else."
  5. #5
    Join Date
    May 2006
    Location
    Posts
    151
    Default "Hi again, thanks for the help
    "Hi again, thanks for the help. I took the plugs out, removed the coil wire, and squirted in a little bit of some standard oil i had (the kind in the little metal can). Turned over a few times and then started right up.
    The starter was a b!tch to align right. It has vertical bolts and without shims it ran right into the flywheel. I removed the solenoid and bolted it up and engaged the gear with my finger until it slid into place. Then I reinstalled the solenoid and fired her up. All works well...so far. Thanks."
  6. #6
    Join Date
    Feb 2006
    Location
    cave City, AR, USA
    Posts
    88
    Default "Jim, I allways suggest WD4
    "Jim,
    I allways suggest WD40 because that's what most folks will have. (If they have any kind of spray oil at all!!) Besides ya can't teach'em EVERYTHING ya know!
    Bob"
  7. #7
    Join Date
    Apr 2006
    Location
    Posts
    861
    Default Why not?
    Why not?
  8. #8
    Join Date
    Feb 2006
    Location
    cave City, AR, USA
    Posts
    88
    Default "I can't be a superior act
    "I can't be a superior acting sob when dealing wit someone who knows all I know plus all he already knew
    Bob"
  9. #9
    Eddie from Oregon's Avatar
    Eddie from Oregon Guest
    Default WD-40 has amazing penetrating
    WD-40 has amazing penetrating ability. Frees stuck things really well. Awfull thin though. Don't know if I'd use it until I had to in a situation like this but I sure it would work. WD-40 is also a good metal preservative but some say that Inox is a little better as a protectant
  10. #10
    Join Date
    Sep 2004
    Location
    Virginia Beach, VA, USA
    Posts
    809
    Default Sounds like a synthetic oil ve
    Sounds like a synthetic oil versus petrolium argument starting all over again...
    I would suggest anything slippery is better than nothing.
  11. #11
    Default "Yep, Troy, That's it."
  12. #12
    mike mccleary's Avatar
    mike mccleary Guest
    Default "hey russ, i used the crank pu
    "hey russ, i used the crank pully and belt to manualy turn over my 3.0 just take up the slack and use the belt to pull the pully around clockwise if you have an ib/ob dont go counter clockwise it may damage your impeller"
Similar Threads
  1. Motor wonbt trim down Even manually
    By big_builder in forum Johnson Evinrude Outboard Archive
    Last Post: 07-15-2008, 05:38 PM
  2. How to manually tilt 1997 yamaha 40 hp
    By Jane in forum Yamaha Outboard Archive
    Last Post: 07-25-2007, 11:01 AM
  3. Can u manually tilt the motor
    By blueyedyankeegirl in forum Volvo Penta Gas Archive
    Last Post: 06-18-2007, 07:28 PM
  4. JWBmarineTHANKSWhere would it be to do manually
    By mamasplace in forum Johnson Evinrude Outboard Archive
    Last Post: 05-28-2007, 10:29 PM
  5. Manually Turn over 30L
    By russ0943 in forum Mercury Mariner Outboard Archive
    Last Post: 05-18-2006, 12:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
