Mercruiser 233 questions
C
Clint Bachelder
Guest
"I am changing the moter in fo
"I am changing the moter in formula 233 and have several questions, the moter is a mercruiser 233 and the stern drive is I believe a 233. The first question is,
I bought a used moter and am installing it, it came with a 164 tooth fly wheel the original flywheel is a 157 tooth model the old fly wheel fits fine on the new moter and I changed the front balencer wheel, I have read the 351 moter is "exteranally balenced" am I going to have a problem engine balence by puting on the old flywheel?
Second is it possible to tell what rotation the moter has, I have looked at the alternator and the air fins look to be set up for left hand rotation."
"Your Boat might be a 233,....
"Your Boat might be a 233,........
But,.... I Think you're Wrong about having a Merc.233,.. with a 233 Outdrive......
I've Never Heard of Either.......
And,....... If You Don't Know what You're talking about,..... Neither do We......"
"The mercruiser 233 is a ford
"The mercruiser 233 is a ford 351 windsor moter that was installed in 1975, I know this due to the fact that I have the book and 351 ford is stamped in the engine. The BOAT is a formula 233, the engine is a 233 horspower mercruiser moter. I found out about the balencing, there is a external wieght on the flywheel, it appears that it is on both fly wheels so I am OK. The Clymers book indicates this is a standard rotation engine so I believe I am OK here also But I have read on the net that some Ford moters with outdrives were reverse rotation moters. I am sorry if I sound clueless but I was hoping I could get some help"
