Need some help 71 searseska 3hp
brandon
"1971 sears/eska 3hp
chassis#
chassis# 217-58541
serial# 151373
also a tag on the motot itself haas two #'s
T-64213A
6512701
i need to know what type of plug and gap. what weight,type and brand of gear lube. where to drain/fill the lube and how much to put in. also need to know what the fuel/oil ratio is. i have these packets of two-stroke oil that is smokeless and i beleive synthetic. one packet to one gallon of gas is supposed to be good for any mix ratio! is this stuff ok to use? if not what is a good two-stroke oil to run in this motor? klots brand oil maybe? thanks in advance for any help. brandon"
Brandon if you go to Brinx Ent
Brandon if you go to Brinx Enterprise web site theres a catagory on there which will have a full listing of what spark plug goes in the model of Eska that you have. Then it's just a matter of looking it up on champion to see what the gap sholud be.
