B
BigJ1
Guest
"I just finished putting a wat
"I just finished putting a water pump in my 6HP 1989 SS Johnson. I did it all by the book. BUT..Since the motor is new to me it does not put much water out of the weep hole at idol in a barrel unless it is in the mid to upper RMP range (again in neutral, and the stream is not that strong but it is a steady stream). Low idol is not a steady stream its a trickle at best. Is that normal? Is there a way to check??"
