L
larry koob
Guest
I have a 1967 Wizard outboard
I have a 1967 Wizard outboard model number COC6506A76 Serial number 1128 Made by Chrysler. The output shaft and seal are worn badly and I need new parts or help in finding good used parts. Also what weight grease do I use in the lower unit after I have this problem fixed? and what is the fuel to oil mix ratio?
Thank you for your time and help.
