2004 Merc 15HP 4 Stroke Console Missing at High RPM
C
Craig Bell
Guest
"Here is what we've had do
"Here is what we've had done so far, at this point the local Merc shop is at a loss.
Changed Plugs, Both coil parts, ignition wiring harness, Reset Flywheel (wasn't balanced correctly from factory) and changed the prop to an OEM merc prop.
Symptoms:
Runs perferctly up to 3/4 throttle on plane. Runs perfectly on full throttle until you reach plane. Once on plane anything above 3/4 throttle leads to significant missing.
Thanks in advance for your help!"
"I have tried 2 tanks, will tr
"I have tried 2 tanks, will try the fuel line.
which harness do you mean? We replaced all the wires from the console to the motor already, are you talking about something else?"
