Power Trim Problems 1998 Johnson 225HP
tjohnson
The power trim and tilt unit
The power trim and tilt unit on this outboard has an internal leak that allows the motor to move down slowly. I suspect a check valve? Is this a repair that can be done at home? Where are rebuilt units available by mail order?
"TJ.... I retired before that
"TJ.... I retired before that unit came into being and I'm not knowledgeable of it. Hopefully another tech will jump in here with the info you need.
Joe
