1984 Dt85 Suzuki HELP
bendro70
"Still can not get it to WOT.R
"Still can not get it to WOT.Rebuilt carbs,cleaned tank,new fuel pump,new plugs,new bulb,checked timing and compression and installed fuel/water seperator.The only thing I have not changed is the fuel connector.Any ideas?Suggestions?Dynamite?"
"No it has recommended prop on
"No it has recommended prop on it.Could something electrical cause this? I can put it in a barrel and throttle it up and will throw water everywhere,but when it is in the water nothing but about 12-1500 rpms."
You should hook up a timing li
You should hook up a timing light and verify that you have proper spark on each cylinder ( use it as a scope )at full throttle. Then look into the carburetors at full throttle with a flashlight and verify fuel coming up each main jet.You have checked the reed valves?????
Reed valves look fine nothing
Reed valves look fine nothing open or broke. I hooked timing light up on each cylinder at idle and all is well. Havent tried it at wot.
