"First, don't skimp and re
"First, don't skimp and replace all bellows and seeing your going to be into it check and plan on replacing the gimble bearing. also a really good time to change water pump impeller.
You can change just the shift cable bellows by
raising drive to limit and carefully pulling shift cable through stern. (do not kink cable!!!) And replace bellows. The black cable end and threaded portion at carb is easily removed to facilitate fitting through stern.
Also a forum search would have shown this.
Be sure to use bellows adheasive, and new hose clamps.
Kurt"
