lezmtaylor
"Hi There,
My first post ,so
"Hi There,
My first post ,so be gentle with me please!!
I have a 26 ft Cruiser fitted with 2 x AQ130C/270.
There is a fair bit of wear in the clevis pins and housings.
Now I can bore out and repin as necessary to remove this play.
The 2 out drives each have a steering arm with 2 holes for mounting connecting rods to.
The set up was as follows:
Starboard arm inner hole (Transom side) was connected by rod to the outer hole on the port arm.
And the rod from the steering wheel was connected to the starboard outer hole.
To me this seems wrong , surely the rods connecting each leg should be connected to the same holes on each leg i.e. both inners or both outers, otherwise the geometry will be incorrect.
The steering wheel rod going to the spare hole.
Am I correct or not ????????????????"
My first post ,so
"Hi There,
