Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 8 of 8
  1. #1
    Join Date
    Jul 2008
    Location
    Glencoe, Al,
    Posts
    2
    Default "This has been a great engine
    "This has been a great engine but yesterday on my way home from fishng it just quit. Acted like it was out of gas. Now it will start, after I rest it a few minutes, but it will only run for 10-15 seconds and then stop again. Any ideas?"
  2. #2
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default The fuel system would be the m
    The fuel system would be the most logical place to start the diagnostic process.
    Elvin
    Solution One Maritime
  3. #3
    Join Date
    Jul 2008
    Location
    Glencoe, Al,
    Posts
    2
    Default Fuel is getting to the carb so
    Fuel is getting to the carb so it must be the carb itself.
  4. #4
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default Clean the carb and cleaning th
    Clean the carb and cleaning the carb means taking it apart and soaking it in carb cleaner for three hours. Spray cleaners are worthless to solve a problem as they are weak.
    Elvin
  5. #5
    Join Date
    Aug 2008
    Location
    Honolulu, Hawaii,
    Posts
    1
    Default "I have a 5HP 2 stroke, the mo
    "I have a 5HP 2 stroke, the motor will start and run for about 30 minutes to get me out of the harbor and where I need to go but when I try starting the motor to get back in. It just won't start. This has happened time and time again. It will start, run for a while, then won't start again for a whole day. WTF!? I need some Guru advice! Changed the fuel line, fuel filter, cleaned the carb, cleaned all the screw down contacts, replaced the spark plug."
  6. #6
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default Get out your service manual an
    Get out your service manual and start running the checks on the ignition system. If they all check out okay then you have a problem in the fuel system or and engine block problem.
    Elvin
  7. #7
    Capt Piscataqua's Avatar
    Capt Piscataqua Guest
    Default "I have a Nissan NS5B- 2 Cycle
    "I have a Nissan NS5B- 2 Cycle 5HP. The engine worked fine all summer until yesterday when it suddenly stalled after runninng full throttle for 5 minutes. It would restart but only run at idle speed. Any accelaration would cause it to stall. The fuel is OK, internal tank filter OK, fuel flow to the carb OK, I cleaned the carburator and it looked OK. The problem still persists. Anyone have Ideas about what is going on? What next to check out?"
  8. #8
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default Do you have fire and compressi
    Do you have fire and compression?
    Elvin
Similar Threads
  1. Replies: 1
    Last Post: 08-05-2010, 06:00 PM
  2. Merc 50 starts and runs but stops when I let go of the key
    By bfoker in forum Mercruiser Sterndrive Archive
    Last Post: 06-23-2009, 08:12 AM
  3. Kohler Gen Starts then Stops
    By richie in forum Miscellaneous marine engine topics
    Last Post: 08-18-2008, 08:56 PM
  4. MAR 8HP Starts on 1st try stops after 40sec won%60t start again
    By Brian Portelli in forum Mercury Mariner Outboard Archive
    Last Post: 01-23-2006, 03:54 AM
  5. Johnson 80 starts up runs 12 secs caughs and stops
    By Bil N. in forum Johnson Evinrude Outboard Archive
    Last Post: 08-09-2003, 09:21 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
