folkboatman
"Two related questions:
1.
1. Several times a year we are out a week or more and up to a month, in salt water away from civilization & freshwater hoses. No opportunity to flush the motor -- which is definitely not good for a Honda BF8A! I have replaced the thermostat twice due to corrosion, and have had the pee hole plug up VERY solid. (Never any overheating, fortunately.) I am now replacing the intake manifold because severe pitting around the thermostat has caused a leak (an external one).
Question: Can I just dispense with the thermostat all together? (Water temperatures here 40s to 50s, rarely around 60.) See recommendation on p.3 of this file, which suggests doing so: http://www.thunderbirdsailing.org/Newsletters/PMITCA_newsltr_Dec%2001.pdf
2. What do you think of the BF8A flushing method shown here?: http://www.catalina-capri-25s.org/tech/tech25/tt028.asp
We flush the motor with the boat tied-up at the dock, by using the Honda fitting that goes over the water intake. Very awkward, hanging over the stern to hook it up, though. Will the method shown work OK if the motor is run with the water intake active, or will sucking in salt water defeat the purpose? (For that matter, I'm never sure I get a good seal with Honda flushing fitting, and some salt water may be going through with the fresh -- 180 degree bend with the hose coming over the stern affects position of fitting.)
Thanks."
1.
Thanks."
