Click for Bukh manuals!
Results 1 to 2 of 2
  1. #1
    gina kalla's Avatar
    gina kalla Guest
    Default "We have on our yacht a diesel
    "We have on our yacht a diesel engine, a Bukh DV20 ME, 20 years old. There were never any problems with it. But one week ago water escaped from the cooling system ( we have a double cooling system ) and run away, causing the engine to overheat. After careful observation we finally saw a small hole under the bolt which connects the fuel pump with the injection pump and saw water assemble around it. However the oil in the engine and the fuel were and still are without any sign of water.
    All the spe******ts who looked at our engine said of course that it was impossible that water should come out of this place. We dried the place, put steel epoxy on it and since then have run the engine several times for one or two hours, without any sign of trouble.
    But the experience was odd and we would like to know what happened. We have no construction plan of the engine. Has anyone any idea what happened or what we should do to avoid problems later on?"
  2. #2
    Default Re: Cooling water escaping
    The water pump has a couple of relief holes that will spill out onto the engine so water doesnt end up being forced into the gearing and engine systems. Check your Lip Cups and bearings in your water pump behind the impeller.
Similar Threads
  1. bf225 cooling water not coming out cooling water indicator
    By tshug in forum Honda Outboard Forum
    Last Post: 07-10-2011, 10:47 PM
  2. No water out of water cooling hole 2006 25hp
    By budjanz in forum Mercury Mariner Outboard Forum
    Last Post: 08-09-2010, 07:58 PM
  3. No cooling water
    By gordon_shaflik in forum Johnson Evinrude Outboard Archive
    Last Post: 03-01-2008, 04:50 PM
  4. Closed water cooling system verses a raw water cooling system
    By Dan Stephens in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 02-19-2008, 01:56 AM
  5. Raw water to fresh water cooling
    By ratmower in forum Mercruiser Sterndrive Archive
    Last Post: 09-16-2006, 07:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
