superamund
"I recently took my regal 2150
"I recently took my regal 2150 with a 4.3 gl VP engine out of winter storage. The engine worked superb before storing it for the winter. Have done proper conservation with anti frost etc before storing it. When I run the engine now it sounds fine and aggresive in neutral when reving it. However when I put it in gear the engine seems to loose momentum and it takes quite a bit of time before the boat plans. When on plane the engnine seems to run proper but only hits around 3500 rpm and around 32knots.. The boat has easily done 45knots previous seasons and had plenty of momentum. Has anyone had simular problems? The boat won't even plan with more than 2 people right now. The engine misfired when I first started it. Have now changed plugs and wires, fuel filter and the engine starts fine and runs great in neutral.
Any Idea? I have also thoroughly washed the hull so there is no growth anywhere which should slow the boat down.
Please help
Kr
Alexander"
Please help
Kr
Alexander"
