"Fred, I looked up the number
"Fred, I looked up the number in my cross-ref charts and can't find it listed - so suspect it is older than the lists I have.
My best guess would be that it came off an early 1960's model somewhere in the 60-100 horse range (but that is almost purely a guess).
If the spline matches up on your 75 horse, give it a try.
A 21 pitch 2-blade would be about the equivalent of a 19 or 20 pitch 3 blade (due to less drag).
Two blade props will generally give you a little better top end speed, but do tend to cause the motor to "shake" a little worse.
If it fits, give it a try. Just make sure that it fits properly into the gear case - any gaps due to not sitting back far enough or due to slightly smaller diameter on the hub can cause cavitation problems that you don't want...."
