"I'm working on a '79
"I'm working on a '79 Tiara 2500 with twin 140's. Got the Port side motor running, but the starboard side motor will only run if I continuously pump the throttle. I understand that there are accelerator pumps on the carbs and this would explain how this is working. Does this mean then that I can rule out a fuel pump as being the problem? Could my problem be Main jets? carb kit? Any help would be greatly apprieciated. Motor has good compression and spark."
