1997 alpha 1 carbureted Chevy 2 bbl speed limited
xz95xj
"In the slip in neutral, 4750,
"In the slip in neutral, 4750, just like the specs. idles fine, starts nice, good fuel. No black exhaust, all seems to be normal. On the lake, max speed is 3500 rpm, 30 mph. usually get 50mph. Engine dies then catches at 1000 to 1400. flutters and accelerates up to 3500 then repeats. suspect fuel starvation. have changed the fuel filter water separator. next step is the carb fuel strainer. I will try the external carburetor checks in the rene batlle email that guy suggested. before I jump into the carburetor and check it for function, foreign material etc. Any things I might be missing? any thing I should do specifically while I am in the carburetor? I think I am not getting max fuel under load so I guess I have to check for foreign material, restriction, etc. the fuel pump is electric. doesn't seem to have any problems. let me know what you guys think."
"what do you call the high spe
"what do you call the high speed jets. I don't see the term in the parts list. its a Mercarb 2 bbl.
Ref.No. Ref.No.
1. Screw, Choke Housing 28. Gasket, Bowl Cover
2. Choke Housing Assembly 29. Fitting, Fuel Inlet
3. Gasket, Choke Housing 30. Gasket, Fuel Inlet
4. Screw, Choke Lever 31. Gasket, Fuel Inlet
5. Lever 32. Spring, Fuel Filter
6. Screw, Fast Idle Cam 33. Filter
7. Fast Idle Cam 34. Power Valve Assembly
8. Choke Rod 35. Gasket, Power Valve
9. Pump Rod 36. Jet
10. Screw, Bowl Cover (Long) 37. Gasket, Jet
11. Screw, Bowl Cover (Short) 38. Screw, Venturi Assembly
12. Bowl Cover Assembly 39. Screw, Venturi Center
13. Pin, Float 40. Lockwasher
14. Float 41. Gasket
15. Needle & Seat Assembly 42. Gasket
16. Pump Shaft & Lever Assembly 43. Venturi Cluster
17. Screw, Pump Shaft Assembly 44. Gasket, Venturi Cluster
18. Washer, Pump Shaft 45. Flat Bowl Assembly
19. Retainer, Pump Shaft 46. Screw, Throttle Body
20. Accelerator Pump Assembly 47. Lockwasher
21. Spring, Pump Assembly 48. Gasket, Throttle Body
22. Retainer, Spring 49. Throttle Body
23. Strainer 50. Needle, Idle Mixture
24. Check Ball Adjusting
25. Accelerator Pump Lever 51. Spring, Idle Mixture
Screw
26. Washer, Inner 52. Screw, Idle Speed
Adjusting
27. Washer, Outer 53. Spring,"
Main metering jets. (36&#4
Main metering jets. (36)?
I have no idea what diagram your parts numbers correspond to.
Take a look at the power valve and venturi cluster too.
"[b]"any thing I should do
""any thing I should do specifically while I am in the carburetor?"
Ayuh,...
Get a Carb Rebuild Kit,+ Properly Install it....
Special Tools required start with Compressed Air,+ a bucket of Carb Cleaner....
Before tearing into the carb t
Before tearing into the carb try running it on
a portable fuel tank. If it runs normally you
may need to replace the anti-siphon valve or the
pickup in the tank may be clogged. Or the vent
line from the tank may be clogged. All related to fuel starvation as load (RPM) increases.
