Dies at idle
kevgrn114
"1979 140 #1
dies when at id
"1979 140 #1
dies when at idle for about the first hour or so, then it will stay started. I have adjusted the idle up about as far as it can go.
What should I check next?"
Choke! If it's a stovepip
Choke! If it's a stovepipe or manifold heated choke coil there may be a blockage in the exhasut stovepipe not allowing transfer of heat.
"Ayuh,...
And turn the idle
"Ayuh,...
And turn the idle back Down,....
High idle Destroys outdrives....."
"I would do a full tune up as
"I would do a full tune up as well.
Rebuild carb, set timing, and any other neglected
maintenance items i.e. water pump, bellows, etc.
Kurt"
