MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 7 of 7
  1. #1
    simon vowles's Avatar
    simon vowles Guest
    Default hi want to no what year is my
    hi want to no what year is my mercury 75hp outboard no9417433 thanks
  2. #2
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,116
    Default "Simon, not sure exactly what
    "Simon, not sure exactly what you have there. Can tell you that the serial number is good for a 1985 model built by Merc/Belgium...
    But not for a 75 horse - the first 75 horses produced had a serial of 9427676 and they went up from there.
    Your serial is for a 60 horse.
    Any chance someone swapped cowls along the line??
    Would need the casting numbers off your top carb to confirm exactly what you have..."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  3. #3
    Join Date
    Nov 2007
    Location
    Ocala, Fl,
    Posts
    307
    Default sorry for the dumb ? but the c
    sorry for the dumb ? but the carb is where you find the numbers cause I can't find any one my dads 75 merc. where on the motor itself do you look. sorry I'm a I/O guy
  4. #4
    Join Date
    May 2007
    Location
    Posts
    9,116
    Default "Ok John, you have about the s
    "Ok John, you have about the same response I do when I look at 5.0 Mercruiser [img][/img]
    I suspect that you are probably looking at a mid-80's model.
    If I'm right you will have a bank of three carbs stacked vertically. As you are looking at the throats of them the casting number should be either on the very top or on the right hand side near the top (near the throttle linkage).
    What you are looking for is a "WME" followed by a couple of numbers or alternately at "3301-" and then some numbers.
    Merc outboards shared blocks amongst a number of horse powers. In the mid 80's the 70/75/80 and 90 all shared the same block - the carbs are the easiest part to cross reference to determine what you have if the horsepower is in question. Otherwise, the other 95% of the motors are all identical and can swap parts back and forth..."
    Graham
  5. #5
    Join Date
    Nov 2007
    Location
    Ocala, Fl,
    Posts
    307
    Default thanks graham and I found the
    thanks graham and I found the numbers they are A115542. these are the ones on the aluminum plate thats riveted to the part that attaches to the hull. sorry not to fimilar with the OB motor terminoligy nor can i spell today. anywho what do these numbers tell me ????
  6. #6
    Join Date
    Jul 2008
    Location
    Halstead, Kansas, USA
    Posts
    1
    Default This seems to be a common ques
    This seems to be a common question so it will be my turn to ask. I recently bought a 1984 Glasstream with a 60 hp Mariner serial #6497220. Can you please tell me what year the motor is? Thank You
    J. R.
  7. #7
    Join Date
    May 2007
    Location
    Posts
    9,116
    Default J.R. that's a 1984 Mercury
    J.R. that's a 1984 Mercury built Mariner...
    Graham
Similar Threads
  1. Year of my 75HP Mariner
    By dak-61 in forum Identifying Model / Year / Horsepower
    Last Post: 01-05-2011, 09:12 PM
  2. What year is my 2stroke 75hp mercury
    By simon vowles in forum Mercury Mariner Outboard Archive
    Last Post: 07-01-2008, 03:17 PM
  3. What year is my 75hp mariner
    By willhunt in forum Mercury Mariner Outboard Archive
    Last Post: 05-29-2008, 04:39 PM
  4. Year 75hp Mariner
    By Russell Tack in forum Mercury Mariner Outboard Archive
    Last Post: 03-13-2008, 07:29 PM
  5. What year is my 75hp mercury
    By Barry Gardner in forum Chrysler Force Outboard Archive
    Last Post: 06-22-2003, 09:19 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
