R
ron t
Guest
My engine overheat alarm goes
My engine overheat alarm goes off and puts motor in safe mode. Put boat in shop was told that the oil injection system was bad. It was disconnected and now I premix. boat ran fine for a few days however when I get into choppy water it will go off again. tried reconnecting oil sensor wires and manually lifting float that did not shut off alarm.I also disconnected the wires to the thermal sensors to see if a bad sensor was triggering it and it still does it. The boat is definately not overheating. I can put my hands on the heads and they are not hot and water comes out the rear like a garden hose stream. Sometimes I get the alarm when I just turn the power on. But it mostly only happens in choppy water. in calm water it often runs on plane just fine.Any ideas
