Results 1 to 8 of 8
  1. #1
    Join Date
    Oct 2007
    Location
    Lawrenceville, GA, USA
    Posts
    22
    Default I have a 1986 chris craft with
    I have a 1986 chris craft with a Gen I Chevy 350. I would like to put aluminum heads on it. I can't afford new aftermarket heads. i was wondering if there were any cars that had aluminum heads that i could use. I know the Chevy LT1 Camaro had aluminum heads but i don't know if that will bolt up to my older block. Any advice would be welcome.
  2. #2
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default Catalin: won't the bolt p
    Catalin: won't the bolt pattern be different?
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  3. #3
    Join Date
    Aug 2006
    Location
    Calgary, Alberta, Canada
    Posts
    2,426
    Default Do a Google search on small bl
    Do a Google search on small block chevy engines and you will find a host of forums that deal with them. Somewhere someone will know about this and whether it can be done.
    Rod
  4. #4
    Join Date
    Jan 2008
    Location
    Lakehills, Texas, USA
    Posts
    220
    Default "Yes, pro-comp heads, 64cc com
    "Yes, pro-comp heads, 64cc combustion chambers,
    2.02 int. valves, 1.94 exhaust and 190cc intake runners. A pair can be had for around 600 bucks and can usually be found on ebay;)
    also the L98 5.7 chevy, found on 1986 to around 1992 camaro firebird or corvette can be used.
    Not all had aluminum heads but they were common.
    Kurt
    P.S. with a rebuild of those your bettor off going pro comp. And pro comp has bronze guides that marine heads also use, and ss valves!"
  5. #5
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,285
    Default "Ayuh,.... Dollar for Dolla
    "Ayuh,....
    Dollar for Dollar,...
    You Can't Beat a set of cast iron Chevy factory Vortec heads.....
    25/ 30hp, right outta the box,..
    This is a Boat......
    You don't see alot of Aluminum heads on Boats for Many reasons...."
  6. #6
    Join Date
    Oct 2007
    Location
    Posts
    22
    Default "thanks to everyone for the ad
    "thanks to everyone for the advice. Bondo, can you elaborate on why you don't see aluminum heads of boats. Those iron heads weight a ton, that can't be good for handling or fuel economy. I know my way around an import engine very well but this is my first time working on a American made engine. On the engines I'm used to, Light weight and good machining are key to a well running, fuel efficient engine. Why doesn't this apply to boats. As Kurt said, if i get the Pro comp heads they have the same valve guides and SS valves that marine heads have. Is there a problem just because they are aluminum? Please keep in mind that I'm not arguing with you. I'm really just trying to understand."
  7. #7
    Join Date
    Jul 2008
    Location
    , sc,
    Posts
    104
    Default "It isn't a problem if you
    "It isn't a problem if you have a closed cooling system like in your car which circulates a water/antifreeze mix. Dissimilar metals like aluminum and cast iron in contact with salty seawater and even some high mineral content lake water sets up potential for galvanic corrosion.
    Just like an aluminum drive unit and stainless steel conponents in the drive. That's why there are zinc (or aluminum) anodes on the drive, to sacrifice them selves rather than the aluminum of the drive unit gearcases. Also some potential
    problems with the different heat expansion ratios of alum and cast iron. That's why the old
    3.7L Merc engines had closed cooling from the
    factory - alum block and cast iron heads."
  8. #8
    Join Date
    Dec 2006
    Location
    Posts
    5,285
    Default "[b]"I know my way around
    ""I know my way around an import engine very well but this is my first time working on a American made engine."
    Ayuh,...
    So you must understand the relationship of moving the Air through a motor,...
    Most boat motors breathe through Really restrictive Exhaust....
    Boat motors also usually top out at about 4800/ 5000rpms, for longevity...
    Google up the Chevy Vortec Heads,+ what they can do,...
    2.02 Intakes,+ 1.94 exhaust valves aren't what it takes to build Torque, down Low.....
    I guess it comes down to the Money,...
    Waste it on aluminum heads, or use Better cast iron heads,+ dump the Money into the Gas Tank...
    My tank needs Gas more than my motor needs aluminum heads..."
Similar Threads
  1. Aluminum versus Cast Iron
    By bulletine in forum Crusader Marine Engine Forum
    Last Post: 08-07-2010, 11:39 PM
  2. What heads fit mercruiser 1996 4.3 gm block number 535
    By seamus in forum Mercruiser Sterndrive Forum
    Last Post: 03-05-2010, 08:13 PM
  3. Building marine engine with 350 block and 882 heads
    By chris0061 in forum Mercruiser Sterndrive Archive
    Last Post: 06-07-2009, 09:52 PM
  4. SB Aluminum Heads
    By 300hb in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 04-02-2008, 08:28 AM
  5. Mercruiser 454 Gen 4 block with Gen 6 heads
    By mopwr2 in forum Mercruiser Sterndrive Archive
    Last Post: 08-07-2006, 08:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
