Alarm on 40 HP mercury
bzerangue
"My alarm stays on constantly,
"My alarm stays on constantly, whether or not the engine is running. I disconnected the oil tank sensor and the alarm stopped, so I changed the sensor thinking it was bad. Alarm still sounds with new sensor, without starting engine. When I hang the tank below the engine head, alarm stops. Tank has plenty of oil and the engine starts and runs well. Any suggestions what my problem might be? I am stumped.
Barry"
on some of the older systems t
on some of the older systems the magnet fell off the sensor making contact with the switch. did you drain the tank and look inside
"Just adding to what JB said a
"Just adding to what JB said and when you said about hanging the tank below the head do you mean up side down? Their is a magnet float in side the tank which sends a signal to the sensor to let it know where the oil levels are.If thats the case,you need to replace the tank ,No fixen that one.Igot a 1994 60 HP mercury with the oil horn going off, it was the main harnes plug.Good luck"
