400800 lower unit
thomtrox
Are the 400 and 800 lower unit
Are the 400 and 800 lower units interchangeable? I have an 800 with a broken hyd. assist shift cable and I also have a good 400 lower unit with the cable intact. Should I swap lower units or just use the cable from the 400?
"Thank you for the response, a
"Thank you for the response, any tips in changing this cable would be appreciated, I am new to this setup but not afraid to tackle it."
I am in the process of changin
I am in the process of changing the shift cable . don't damage it a new one is $500.00 there are also TWO similar cables wrong one will shift backward. look for rings or no rings on the upper end of the cable sheith. I would like to know how to remove the pins in the little geerbox for the wheels?
"I just got finished changing
"I just got finished changing the cable from the 400 unit to the 800, went very smooth. I changed the cable with the assist assy. attached.
thanks for the help here."
